Browse Forums Renovation + Home Improvement Re: How much floorspace does a set of stairs take 3Mar 08, 2013 10:28 pm I always recommend that the stair width should be a minimum of 1m wide - more if possible. That being the case you would lose just over 4sq m for a 2400mm high ceiling. Obviously if the ceiling is higher or you opt for wider stairs this would increase. Stewie You will need to replace the entire stairs. Carpenter is the trade you're after. 1 4330 Got my stairs designed like this with 250mm Gap marked below. Gap is bec of 2 steps added between two landing area… 0 4851 Move your linen into laundry and access laundry from your present linen space 1 7984 |
