Browse Forums Renovation + Home Improvement 1 Mar 04, 2013 11:43 am I am planning to replace my existing roof, made up of concrete tiles (75%) and colorbond (25%). The roof is OK, but ugly and there are to many nooks and crannies where tiles and colorbond bits come together. No wonder I have possums as neighbours and whenever there is a torrential downpour I pray the roof won't leak (it doesn't, but there is always the fear ) The idea is to replace it with a single solution (probably Nu-Lok) to improve looks and weatherproof the house. This would require a redesign of part of the roof (the colorbond part, about 25% of the roof) to increase the pitch of the roof. Apparently Nu-Lok can handle roof pitches as low as 5 degrees. Would you consider involving an architect for this new roof design (which also includes replacing soffits, fascia's and all downpipes, etc.), or just work with a builder/roofer? Thanks Rgds Chris Re: Involve architect or not? 2Mar 05, 2013 9:22 am I'd get a rough floorplan and a couple of elevations drawn up by a draftsman. Neither have to be in great detail as you are only changing your roof but a few arrows and explanation notes would cut out any uncertainty on the builders, carpenters or roofers part. Stewie Your build is relatively simple, I believe your job can be easily done by a good building designer, you really do not need to pay for the architect. Remember, architect's… 3 10990 I've just had a look at the website. The company are just building broker's. There are plenty of similar companies that basically draw your plans (they own them so you… 8 10947 The HIA contract, in the term & conditions section states that "Commencment" is deemed when the drainage is started or the piers are dug or the slab is formed up (incase… 2 6182 |
