Browse Forums Renovation + Home Improvement 1 Feb 20, 2013 9:24 am We are getting an extension done at the moment. Regarding roofing I was given an option to use second hand cement tiles which match the current tiles, but I did not want them and opted for new ones instead. The new tiles are also cement tiles but are slightly wider than the existing tiles. I asked the tiler to give me a quote for tiling the whole roof and the quote came out to be $7000 for Bristile yeoman tiles. The area to be tiled is 131 sq. m and the house is a single level house. Is it ok price wise? The tiler said his charges are $57 sq. m. I also understand that new tiles and old tiles will make my house look like having two roofs, but I don't mind it as the extension is at the back and no can see from the front. Re: Redoing a roof... 2Mar 13, 2013 7:02 am I'm a little further behind you. We putting an extension on the back of a period home with a tiled roof, am tossing up between: (a) Fixing the tiles on the old part, and adding new tiles to match on the extension (b) Fixing the tiles on the old part, but using colourbond on the new. (c) Stripping the lot and replacing it all with colourbond Waiting for quotes at the moment. Did your $57/sqm include tiles? Cheers, Dim Re: Redoing a roof... 3Mar 13, 2013 9:27 am We ended up having new tiles on the new part of the house. If I had more money Colorbond would have been the preferred option on the whole house. The $57m2 quote included tiles as well. 2 9419 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28290 traditional gable roof facade - Have you did the dark and light gray color combination in facade with gray stone in facade… 0 4203 |
