Browse Forums Renovation + Home Improvement 1 Feb 14, 2013 11:03 pm We have a double brick 3x2. The garage is right next to the main bedroom (part of the house) The roof in the garage is about 30cm lower then the house. We want to turn the garage into the master bedroom with an ensuite. How much are we looking at? Just a rough guess. Re: Renovation Cost.. rough ideas? 2Feb 16, 2013 9:02 am It won't be legal due to the ceiling height. So do you mean to do it illegally? You will also have problems if you try to sell it. But, that aside, sheeting the walls with gyprock is not expensive. You could get a handyman (assuming you are not knocking out walls). You need a plumber for the ensuite. If you source tradies yourself you will save money. Sorry can't give a figure. Hello Josh, This is Irving from PRIMA, we are a manufacturer of the staircase, railings, kitchen cabinets, windows, doors from China. If you have requirement to purchase… 0 5456 Coming back to your old stomping grounds, huh? Renovations on a budget can be quite the journey. It's like giving your house a new lease on life. The twist of not knowing… 1 3476 Assuming the structure of your cabinetry is good then I would DIY everything as follows: - replace your counter tops entirely, - replace all drawer runners with soft close… 1 4782 |
