Browse Forums Renovation + Home Improvement Re: Attaching rings to brick 2Jan 20, 2013 1:18 am Personally I wouldnt. Lintel bricks are only sat on the lintel beam and held in place by those above, which may become loose once the weight/movement is increased Arfur Re: Attaching rings to brick 3Jan 25, 2013 2:28 pm I'm with Uncle Arfur. It's now illegal to attach basketball rings to bricks above garage doors, and the setup you're describing would potentially be required to bear a lot more weight than a teenager occasionally slam-dunking. http://www.buildingcommission.com.au/re ... 29_NOV.doc I plan on installing an undercover walkway (awning ??) from my carport to the back door as shown in sketch. I will be using Boxspan Beams and have no concerns regarding… 0 763 DIY, Home Maintenance & Repair Follow up question - any ideas on how to set up a portable air conditioner through this kind of window? 1 6236 2 8359 |
