Browse Forums Renovation + Home Improvement 1 Nov 04, 2012 11:43 pm Just after an idea of what you extension ended up costing. 1 Size of extension in M2 2 Cost 3 year 4 Builder or Subcontracted owner build? 5 State- SA, VIC etc 6 Tips for those of us thinking about doing it (Advice) MUCH APPRECIATED INFORMATION - THANKING YOU ALL IN ADVANCE. Andrew Re: "STICKY" - What did your extension end up costing? 2Nov 07, 2012 5:51 am I am looking at constructing an 80m2 extension for $140,000. It is a double-storey extension on a house we built ten years ago. The price is a very good one. Tip. Design is everything and don't make it too small as you will be paying a lot for each sq metre. cheers Re: "STICKY" - What did your extension end up costing? 3Nov 07, 2012 3:15 pm Hi Leighton, You wrote "It is a double-storey extension on a house we built ten years ago" Do you mean you are adding an extension on top of your home or a two storey "new" build to the rear of existing home(ie 80m2 being 40m2 ground floor and 40m2 top floor. Thanks Andrew Re: "STICKY" - What did your extension end up costing? 4Dec 23, 2012 7:39 am Hi We finished an extension and reno on our 30s art deco home a year ago: 1. 64sqm (kitchen, dining, 2nd living area) inside ground floor extension , plus deck and pergola and reno to existing floorspace to create 2nd bathroom and study 2. cost $330,000 (exc fees and landscaping) - could have been done for less but we chose high quality flooring, appliances, joinery etc 3. 2011 4. Adelaide sa 5. Builder, architect project managed 6. Tips - be prepared to make a lot of decisions on everything from type of flooring thru to where you want your light switches - I found this overwhelming and rushed a couple of things and now hate my bathroom handles! (they have two drill holes and I can't find any suitable replacements) Hope that helps someone out there! Minimum overhang into gutter must be 50mm, turn down tool should not split the sheet. it seems wrong tool for the profile was used, the flashing cannot slope back. Rib… 2 2092 Electrical just got back to me and said the most they can provide is a single power point on the Bedroom 1 side of that wall. After handover, your towel rail installer… 2 3815 |
