Browse Forums Renovation + Home Improvement 1 Oct 28, 2012 8:23 pm We have a house which has a driveway that runs down the side of the house (but no carport/garage). We were interested in installing one however the driveway does not appear to be wide enough to park a car in (and get out both of the drive/passenger side doors). I was wondering if anyone knew of any websites that detailed innovative space solutions for carports (not sure if there is a solution but thought that I would ask). Re: Carport/garage solutions for restricted space 2Oct 30, 2012 7:14 am Short of widening the area ( meaning carving off 1m from your house ) or having the carport /garage right up to the front boundary, i don't think you will find what you are looking for. How much distance is there from your front boundary to the front of your house ? Stewie Re: Carport/garage solutions for restricted space 3Oct 30, 2012 9:31 am Buy a smaller car? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Carport/garage solutions for restricted space 5Nov 05, 2012 12:46 pm The council may not let you build a garage but they may let you do a carport there. A few inquiries at your local council will point you in the right direction. Stewie In the end, two pieces of treated timber (20mm thick) were bolted onto the joists and planed when there was too much sticking out. Passed inspection. 13 7801 I would find out how deep your clay base is and depending on the depth install a cut off drain which is more than a normal agi drain. Where the neighbouring walls is… 2 3148 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9960 |
