Browse Forums Renovation + Home Improvement 1 Oct 10, 2012 10:36 pm Hi All, I am in South Australia and have been advised that I should budget aprox $35 per m2 for carpenty (first fix / rough-in) as pertaining to wall area. This would include materials (mpg10 90x45) and labour Would anyone know if this estimate is in the ball park? Thanks Andrew Re: Need advice on carpentry cost per sq meter ? 2Oct 16, 2012 6:39 am are you building on a slab? talking about framing the house walls and installing trusses? bit unclear sorry. also size of house is important. Re: Need advice on carpentry cost per sq meter ? 3Oct 18, 2012 12:06 am Yes, building on a slab. 2 story with second storey using timber truss floor with tongue and groove flooring. Total size is 200m2 with 130m2 on ground floor and 70m2 on 2nd level. I can easily find out the material cost per m2 ($3lm for timber 90mmx45 mgp10 @ 450mm centres with single bottom plate and double top plate.) but wanted to know how carpenters charge for their labour? ( Obviously Excl doors and windows. ) Please advise, Andrew Re: Need advice on carpentry cost per sq meter ? 4Oct 18, 2012 8:55 am I don't know about a square metre cost, but our chippy charged us $45 per hour with our build. I don't know how you calculate a sq metre rate as apart from labour there is a lot to factor in. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Need advice on carpentry cost per sq meter ? 6Oct 19, 2012 12:33 pm You would get a more accurate cost if you looked for cost per lineal metre of wall rather than sq m. Some truss & frame companies would probably give you a rough idea too. Stewie 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 3604 Levelling compound Ardit is the best but buy a bag of sand and make sand dam to protect your wood floor 2 15259 |
