Browse Forums Renovation + Home Improvement 1 Sep 24, 2012 12:33 pm Hi All, Looking at doing a major reno. Our current ceiling height is 2400 and we want to go to 2700, New roof trusses will be going on. Looking at using 8ft internal doors so new window head height will need to be 2400 We would like to keep the existing brick front of the house and frames, question is are we able to extend the height of the existing frames to make up the extra height or do they need to be redone. Thanks, Andnic. Re: Wall Frames 2Sep 24, 2012 7:12 pm Andnic the load bearing walls should be redone and the non loadbearing can have their height extended. @builderforlife Building inspector and passionate about construction When you need an expert to take a look. Re: Wall Frames 4Sep 27, 2012 9:38 pm Brickwork will nedd to have extra height also Regards M @builderforlife Building inspector and passionate about construction When you need an expert to take a look. Re: Wall Frames 5Oct 05, 2012 7:24 am I don't think an engineer would let you simply tack on another 300mm to all your walls. We have extended some walls up in the past where we had to take every second stud all the way down to the existing bottom plate. We had to strip all the existing gyprock off to do this. This wasn't as big a drama as it sounds because the client wanted to run a lot more wiring and install better insulation anyway. I'd take some photos of your house and go see a structural engineer for some advice here. Stewie That sucks! Hope it all works out. Good to move away from steel anyway for all your reasons, but it's also thermally poor. 16 17858 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8306 |
