Browse Forums Renovation + Home Improvement 1 Aug 21, 2012 12:54 pm We are thinking of buying a house - but it needs a new roof as the pitch is very low. Its a modest 4 bedroom single level home - couldnt even guess at the area - but to re-roof an old home - has anyone any idea of a ballpark figure of costing using clay tiles? That is - the carpentry work, tiles and guttering. Actually , my preference would be for charcoal coloured shingle roof tiles - but that will depend on cost - do they cost much more than other tiles? I'd love to buy this house but if roofing is too expensive we will look for something else Re: Is it expensive to re-roof an old house? 2Aug 21, 2012 1:35 pm I've done this! As part of my extending and renovating my early 80's home I demolished the existing colorbond roof (low roof pitch also) and have replaced it with a new glazed terracotta tile roof. Here's extremely rough figures on what I paid to do it (my house is around 380m2): New trusses - $14000 Roof tiles, battens, tile clips, batten screws - $20000 Sarking - $1000 Anti-ponding boards, fascias, gutters, silicon - $4500 Mortar (sand, cement), pointing - $500 Fibro and paint for soffits - $1500 All up this comes to about $41,500, but doesn't include any labour expenses (in my case I did all my work myself). You also need to take into account: Additional timber required to strengthen your house frame for a possibly heavier roof load Engineering fees (engineer needs to assess your existing frame) Re-plastering ceilings and cornices where existing plaster is fixed to ceiling joists Re-installing ceiling light fittings, vents, etc Electrical cabling work to re-run any cabling that might be affected Hire fees for tile cutting saw (or just purchase one) These items are just off the top of my head, but I think I covered all the major stuff. I'm happy to answer any additional questions you might have. Re: Is it expensive to re-roof an old house? 4Aug 21, 2012 1:51 pm Thanks Shane - that gives me some sort of an idea. Do I look like the kind of girl who could put on a new roof? No! Will have to get in a roofer for that! I checked your blog and you haven't posted anything for a while - did you finish your roof? If so - can you share a picture of the finished product? Re: Is it expensive to re-roof an old house? 5Aug 21, 2012 1:54 pm Well the woman who lives next door to the house we are interested in has a roof with a similar pitch. She says that its too low and that when it bucketing rain, because the roof pitch is low the gutters cant get rid of the rain quick enough and the guttering cant cope with the rain - so she has internal water damage. Thats the only reason for changing the pitch..... Re: Is it expensive to re-roof an old house? 6Aug 21, 2012 1:57 pm I think there are better ways to go about this. How low is low???? If it is a tiled roof and has low pitch I would consider going to colorbond and look at the gutters and downpipe system. A higher pitched roof has more area and as such you could end up putting more street on the drainage system if it is the main problem. Re: Is it expensive to re-roof an old house? 8Aug 21, 2012 2:34 pm Unfortunately I haven't updated my blog for some quite time, and while I don't have any pictures of the completed roof I've got a few of the final stages. I forgot to mention roof pitch in my first post - my original roof had a roof pitch of 11 degrees, while the new roof is 22.5 degrees. As for my reasons for replacing the colorbond with a tile roof, I prefer the look of tiles (I think they look more "prestigious") and I hate the sound of rain on a tin roof, which makes me feel like I'm in a shed. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Is it expensive to re-roof an old house? 10Aug 21, 2012 4:42 pm Judging from the prices on the following page, shingles are slightly more expensive than other "shaped" terracotta tiles (I bought my tiles from the same company): http://www.onlineroofing.com.au/show_product_image_list.aspx?cid=112 Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10206 Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 8070 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4896 |
