The house is on a gradual sloping 850sqm block with limited side access. The stumps are the original timer ones and despite most likely needing to be replaced in the next few years are in reasonable condition for there age. The house is about 800-1000mm off the ground at the front and at its highest point is 2400 at the back.
The Plan:
I would like to avoid having to raise the house due to the extra cost, I am no expert but I do believe with some small excavation work I will be able create legal building height by cutting 600mm in the heights point into the block. (Despite pictures shown we are only planning to build half way up underneath where current height is 1800mm. We would need to escavate extra amounts to allow for concrete slab. There is some concrete already under the house but is only 80mm deep which would need to be removed.
The idea is to create an extra 2 bedrooms + living area and bathroom with access through an internal staircase in the upstairs sleepout opening up to patio/alfresco underneath the existing upstairs deck. There is an existing toilet downstairs which is where the new bathroom would be located so sewage and water supply exists in the prime location.
I am not sure whether I should replace all of the stumps using timber at the front (for originality) and in the area we are building to use narrower metal stumps.
We don't want to just pay someone to do the entire thing from start to finish as this will prove to be very costly. My brother can do all the electrical work as he is an electrician.
Questions.
Where do we start?
Who would I use to get plans drawn up?
Do I need an owner builder licence or similar?
What type of slab would be required?
Would I need to get soil tests done?
What costs will be involved?
What should I look out for?
What do you think this will cost me done right and cost effectively?
When building underneath what would the most cost effective way of building the external walls? Weatherboard or brick?? (This will not be visable from the right hand side pictured or the front)
Would you use VJ paneling for the interior walls and roof same as upstairs or use plasterboard?
I will update as we go, I have a couple of photos of the house but will take some more photos this week of the areas under the house and at the back so give more understanding of what we are doing.
Please feel free to give advise and recommend trades and estimated costs to do individual things.
Thanks Sam
