Browse Forums Renovation + Home Improvement Re: Repointing brick work 2Aug 11, 2012 11:24 pm Cant help you with the rate but tuck-pointing is a raised rounded white pointing usually used on Basket range stone or the like, whereas 'pointing' is just replacing the mortar in conventional but fretted brick joints and I imagine would vary greatly in price Arfur DIY, Home Maintenance & Repair could be the footing or being hard up against the other wall with no expansion joint or both. You could try again with brick mesh and use some sticky back foam against the… 1 1105 Block of two storey townhouses requires painting on the roof. A brick parapet wall separates each unit and extends above the tiled roof. The parapet walls require sealing… 0 3503 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 10106 |
