Browse Forums Renovation + Home Improvement 1 Aug 04, 2012 2:40 pm Hi, our 1950's weatherboard is in need of a new roof. It currently has glazed terracotta tiles which are fretting badly and need replacing. Has anyone recently replaced an existing tiled roof with either a new tiled roof or colourbond steel? Why did you choose what you did and are you happy with it? Was the cost a factor and what did it cost in the end? What are the pitfalls that you wish you had known before you made your decision? Thanks for your help! Barbara I plan on installing an undercover walkway (awning ??) from my carport to the back door as shown in sketch. I will be using Boxspan Beams and have no concerns regarding… 0 781 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12070 Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6468 |
