Browse Forums Renovation + Home Improvement 1 Jul 25, 2012 9:22 pm Hi Guys, I have attached 2 pictures of a doorway in a garage. I removing the roller doors and building a wall to fill the hole. The floor for the bottom plate is on an angle and I just wanted opinions on the best way to tackle this. Probably the cheapest way and also the best way. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks. Re: Building wall on angled floor 2Jul 25, 2012 9:38 pm Not that hard. one way is underpin the current slab and pour a new area that fits with the old and then a normal stud wall. Or build a stud wall with the bottom plate on an angle and bolt/ramset or similar into the existing slab. Given it's not load bearing either should be suitable. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16562 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17525 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5188 |
