Browse Forums Renovation + Home Improvement 1 Jul 19, 2012 11:30 am Hello, Im looking at doing a feature wall using some beautiful rustic timber i have procured, can internal walls be clad in non fire treated timber (for an aestetic look), whilst still meeting fire resistance standards (the entire wall section) and furthermore can any one recomend how i could fix the lengths? Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16039 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12126 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11181 |
