Browse Forums Renovation + Home Improvement 1 Jun 29, 2012 2:47 pm The putside of my house is covered in 2"x4" glazed tile. I'd like to render over them if possible, but I'm not sure what would stick to the tile. Would something like Dulux Full Cover Texture work (should also fill in the joints)? If not, what would be the easiest approach? yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5241 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4897 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7497 |
