Browse Forums Renovation + Home Improvement 1 Jun 14, 2012 9:40 am Hi, we just bought a property around Earlwood and looking to add a second floor (3 bedrooms) on top using fibro. The property is brick veneer built on top of a rocky hill. If you have experienced this before please let me know roughly how much this will cost and what is the process for getting a structure engineer assessment i.e. before involving an architect or after etc.? Your advice is much appreciated. Thanks Re: extending up 2Jun 20, 2012 10:36 am Work out your budget first, do a quick scale drawing of the upstairs layout then get an engineer to have a quick look for whether it is possible or not. I tell my clients to allow approx $2500 per sq m of extension whether ground floor or upper level for the building work alone. This allows for everything bar floor coverings ( carpets ) and window coverings. Fees to the council, surveyor, structural engineer and draughtsman would probably set you back another $15,000 Any structural work to the lower level or any changes to the ground floor would obviously be on top of that too. Say upstairs you wanted three bedrooms, another bathroom and a second living area totaling 60 sq m and the engineer wanted two beams installed to carry the extra weight . 60 x $2500 = $150,000 Fees = $ 15,000 Beams etc = $ 5,000 Total = $170,000 Note this is a rough guide only. Yours may be much bigger or smaller with many upmarket features and require a lot more ground floor work. Stewie If your patio is going to be 35 sqm then that's going to need Council Approval. The fact that they previously approved your 25sqm patio will be irelevant 1 5496 Ask for some kickplate to be added and also for tradies to be requested to use lanyards on tools on that side of the building. Be respectful and have the discussion… 1 1685 There is insufficient information to give a meaningful answer. You should talk to council planning. Apart from building construction issues, if you are adding floor area… 1 7978 |
