Browse Forums Renovation + Home Improvement Hello! I'm new to this forum and in need of some advice. Should I put an art piece on the blank wall and if so what should I put? Appreciate your help! 😃 0 847 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10658 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5900 |
