Browse Forums Renovation + Home Improvement 1 Apr 20, 2012 7:42 pm We are going to add an extension to our lowset house (sits on brick foundations) Who do we get in to build up foundations? I'm thinking of concrete in the ground down a certain depth and a steel posts at height to suit existing building. How much in dollar terms does one expect to pay per support? Re: Foundations - Who builds them? 2Apr 20, 2012 7:55 pm tocpcs We are going to add an extension to our lowset house (sits on brick foundations) Who do we get in to build up foundations? I'm thinking of concrete in the ground down a certain depth and a steel posts at height to suit existing building. How much in dollar terms does one expect to pay per support? You will need to get plans drawn and engineered to find out what is required. Unfortunately its a little more complicated than filling a trench with concrete and steel posts. BUt to answer your origanal question, the concretors normally do your footings. Cheers mgilla Re: Foundations - Who builds them? 3Apr 20, 2012 8:01 pm mgilla You will need to get plans drawn and engineered to find out what is required. Unfortunately its a little more complicated than filling a trench with concrete and steel posts. BUt to answer your origanal question, the concretors normally do your footings. Yeh, no doubt it's not that simple - but I'm aiming for a rough price. Concrete is minimal in the extension - the only concrete will be in the footings. OK, so after we finish drawing up ur rough drawings, we go to ... ? to draw plans up. The plans are drawn, we get council to approve. We then employ a concreter? to put the foundations in - they mark it out too do they ? I doubt the chippie doing the frame work will be arranging that - so that must be something we take up..? Re: Foundations - Who builds them? 5Apr 20, 2012 8:19 pm amgsl55 owner builder I assume? Sorta - I'm planning on getting the extension water tight, and then finishing the interior (i.e. framework, sarking, roofing, cladding) all done externally - then I take my time doing the rest. Hope to save a chunk on labour in the process. So, from what I gather: - We find our plan (might be asking for feedback on a few designs soon). - Take what works to a draftsman, get him to measure the plans to size? (so they'll want the current measurements, positions, etc) - they'd do a site visit for that normally? - Structural engineer for footings, determine which internal walls are safe to remove / replace with beams. - Concretor for footings to structural engineer specifications. - Framing through carpenter. - Roof trusses done by carpenter, roofing by roofing company. - Cladding by carpenter. .. Then it's all water tight. Hope I've got that much right, that's pretty much the thick of the work that must be done correctly, and timed together too. Re: Foundations - Who builds them? 7Apr 25, 2012 12:11 pm and your owner builder's permit. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Foundations - Who builds them? 8Apr 25, 2012 1:01 pm Pretty much got it all there, You may be able to get a Chippie who can do the setout and footings as well. The footing may be as simple as a 200mm trench with a single 3 bar y12 or a 600mm trench with a y16 cage. Depending on how much footing you have the price difference can be fairly substantial. When you think you have everything covered and have an idea on what it's going to cost. Add another $50-$100K to the total price and you will be somewhere near it Cheers our situation was a bit of a guinea pig in that structural work by the previous builder was defective and the house was almost completed, and our structural engineer… 1 4971 Hi, We are looking for a builder that can build a small home (smaller length) on a sloping site. We came across Mojo's Zephyr design 10.6 m wide and 11.5 m length. Does… 0 23017 I haven’t. But have a Lowe Design home. Not only did I find Matt Lowe patronising and a bully, but the home is NOT TO CODE. I have water coming through the bricks… 1 14371 |
