Browse Forums Renovation + Home Improvement 1 Apr 02, 2012 1:38 pm Hi all, We're thinking of re-cladding our '70s wood frame pole home with metal cladding (corrugated iron/zincalume/mini-orb). In the early stages of deciding on material, getting quotes etc. (We would be hiring pros to do the work.) Would love to hear of anyone else's experience with this material, positive or negative, and ballpark costs per sq. m. if possible. Also, with the home being raised off the ground >2m we are assuming scaffolding would be required? Would be interested to hear experiences of how this may add to the cost & complexity of the cladding job. Thanks! Stu Re: Corrugated iron wall cladding: experiences? 2Apr 22, 2012 11:21 am going down the same route myself this year. only parts of my house are more than 4m off the not very level ground. are you in WA cause I have found a lot of cladding on the brand name websites is not available in Perth as for scaffolding I am thinking of buying 2nd hand, getting it professionally erected, leaving it there for 6 months then selling it rather than renting. This is because apart from recladding I will be running new wiring, insulating etc etc so would rather just potter along than have a rental schedule hanging over my head Re: Corrugated iron wall cladding: experiences? 3Apr 22, 2012 9:28 pm Stu I have never recald a home, but we have used metal clading extensively on new homes particularly in bushfire prne areas. The materail cost typically $ 45 a square metre for zincalume and about $50 for colourbond, but get some quotyes from local roofing companies or carpenters (not plumbers) @builderforlife Building inspector and passionate about construction When you need an expert to take a look. Re: Corrugated iron wall cladding: experiences? 4Nov 28, 2012 4:59 pm Hi, i recently replaced wall cladding in my home, for the cause i consulted http://www.staxstone.com/, till date the installation seems fine. Re: Corrugated iron wall cladding: experiences? 5Dec 03, 2012 9:29 am tracyx Hi, i recently replaced wall cladding in my home, for the cause i consulted http://www.staxstone.com/, till date the installation seems fine. Nice spam! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4897 We have a Victorian style ripple iron fence out the front that has some moulded timber capping. Probably 15+ years old and has cracked and splintered in parts...not really… 0 2495 Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4494 |
