Browse Forums Renovation + Home Improvement 1 Mar 26, 2012 10:21 am Hi everyone, New to the forum and new to renovating. We are looking to add a room to the back of our fairly new house (modern, Mirvac built in 2005). The room would be on the ground floor and approximately 5.5m x 3.5m. Also looking to remove our kitchen, currently on the back wall, replace with bi folds and move kitchen to the side wall, opening the house to the smallish back yard (add a pool later). So my questions are: 1) can anyone explain the process for me? Do I need a draftsmen or can I find a one stop shop building company? 2) Can anyone recommend a good builder? 3) Is there a rough per sqm cost for extensions? Just trying to get a ballpark. I know its hard, based on fittings etc, but thought someone might have experience in Brisbane. 4) Any ideas on the cost of a new kitchen - not top of the line, but premium. Thanks in advance, I appreciate your help. Leah Re: Room extension - Bulimba Brisbane 2Mar 27, 2012 8:51 am Go to a draftsman and get drawings for planning permit Apply for planning permit Get draftsman to do working drawings Apply for building permit Get some builders to do give you quotes OR become an owner builder and get quotes from tradesman (you will then co-ordinate tradesmen / mangae the build yourself) Re: Room extension - Bulimba Brisbane 3Apr 12, 2012 11:04 am We just had our first quote come through and were a bit surprised. For a small 17sqm extension, removing the kitchen (on the back wall) and replacing with bifolds and putting in a new kitchen, it came in at $165k. Here's hoping some other quotes come in much less. Can you "bargain" with builders? Hello Josh, This is Irving from PRIMA, we are a manufacturer of the staircase, railings, kitchen cabinets, windows, doors from China. If you have requirement to purchase… 0 5419 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8373 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6137 |
