Browse Forums Renovation + Home Improvement 1 Mar 18, 2012 1:45 pm Coming from a complete novice, so forgive me for my question, but we are considering extending our house up, and I was wondering would we be able to use the same roofing trusses and tiles again? The extension will be a carbon copy of the ground floor, maybe slightly more narrow than what it is now (same length), the ceramic tiles are in excellent condition, so really, I am wondering can this be done (albeit wtih a few modifications to the trusses)? Would we be saving money by doing this? Thank you, Re: Extending up 2Mar 19, 2012 1:21 am When I worked on this type of extension many years ago, they never altered trusses as they are machine made. At times they extended the external walls up, leaving the original eaves and shortened roof line to break the bareness off a plain 2 storey wall. Errr ceramic tiles? Do you mean cement roof tiles? Most existing tiles were saved (where possible, as many were broken) and used across the back of the addition with new ones used at the front to cut costs. Your builder will advise you best when quoting on your plans, but trying to do things on the cheap is fraught with danger. Arfur If your patio is going to be 35 sqm then that's going to need Council Approval. The fact that they previously approved your 25sqm patio will be irelevant 1 5500 Ask for some kickplate to be added and also for tradies to be requested to use lanyards on tools on that side of the building. Be respectful and have the discussion… 1 1685 There is insufficient information to give a meaningful answer. You should talk to council planning. Apart from building construction issues, if you are adding floor area… 1 7979 |
