Browse Forums Renovation + Home Improvement 1 Feb 27, 2012 6:57 am I am helping a friend to fix a saging gyproc cieling, can anyone tell me what to use to hold it up, it was told to use hemp scrim but I do not know what that is. Re: plaster cieling 2Feb 27, 2012 7:03 am It depends on the condition of the plaster, but a start would be to prop it up and refix it to the bottom plate, get some stud glue in if possible. If it is quite bad i would install a few more trimmers between the bottom chords making sure you have stud glue on the bottom before you re-screw. Use offcuts of something larger like lining boards to give a bit more strength every 300mm or so until the glue sets. Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5024 yeah i couldnt picture it issue either, but i could clearly picture what they were doing wrong haha 2 5294 Our 6m high Cathedral ceiling has 0 insulation, just plaster, wrap and tiles as far as I can tell. Wife likes the exposed beams, I hate the $600 per month heating bill,… 0 13478 |
