Browse Forums Renovation + Home Improvement Re: Bifolds & Stackers & Floors, oh my! 9Aug 10, 2012 8:30 pm Have you checked out the bi fold doors? We just put some in and the part that the doors sit up against (bottom seal) is a couple cm high to create a seal. Not sure if this amount would be okay with you? Ie: the inside floor sits flush with inside of doors and the deck sits flush with the outside of the doors hover there is a slight drop to make the seal. Hope that makes sense! 2 4688 3 5598 Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 9157 |
