Browse Forums Renovation + Home Improvement 1 Nov 07, 2011 1:44 pm I am very new to the forum and property industrie I recently bought a house, We need to fix following issues in that property 1. Bearer needed to be replaced 2. Painting the house 3. Carpet laying 4. Lounge-1 and 2 Timber flooring. They have carpet now. under the carpet it's pine wood. what is the best Timber flooring. if i get the sanding and polishing on this pine wood, will they look good? Pl suggest me 5. Kitchen bench top replacement. Will you suggest me who will fix bearer and how to get quotes from them. Let me know the best person's contact for the above jobs. thanks in advance Re: who will do the bearer replacement? 2Dec 09, 2011 9:53 pm 1. Bearer needed to be replaced (builder) 2. Painting the house (hire local painter if you don't want to do it yourself) 3. Carpet laying (ring a few carpet shops to give you a quote) 4. Lounge-1 and 2 Timber flooring. They have carpet now. under the carpet it's pine wood. what is the best Timber flooring. if i get the sanding and polishing on this pine wood, will they look good? (I'd just get them polished). Pl suggest me 5. Kitchen bench top replacement. ( look for local kitchen shop (not the big kitchen places) Where are you located. If in Sydney I can recommend some people. Re: who will do the bearer replacement? 3Dec 09, 2011 10:09 pm Why does the bearer need replacement? I'm just interested to know as if it's termite damage you may have to solve that problem as it may still be ongoing. I had a bearer replaced on my house which was the result of termite damage. I used a reblocker/restumper as to replace it you need to jack up the house from under the joists which only a reblocker generally has the equipment for. Just look up restumping/reblocking for your local area - it may take a few calls to find someone willing to take on a smaller job. The cost for me was about $1300 which also included a section of flooring which was eaten by termites. Done right there shouldn't be any cracking to the plaster inside as they only need to jack up the house very slightly. Seconded; we just used these last weekend to build a small deck. They worked perfectly as we have bluestone in the area where we wanted to build so digging down was not… 8 9755 ![]() Hi Mrboh Just wondering if you have any BAL or flame zone issues on your block, as getting compliance with BAL requirements whilst doing bearers and joists is tough. Not… 1 8922 ![]() Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 48532 |
