Browse Forums Renovation + Home Improvement 1 Nov 29, 2011 9:26 pm Hi All, I have recently built a timber deck in an alfresco area and am planning to clad the ceiling to match. The ceiling will need downlights installed and i have noticed that most 'standard' dls state not for use in timber... ...does anyone have suggestions for products that are suitable? Google brings up lots of pictures of timber ceilings with DLs installed but i find precious little info on what to use. Regards, Al Re: Downlights for a timber ceiling? 2Nov 29, 2011 10:42 pm Maybe look for a fire rated downlight. They have a little fire symbol on them. my house blog: http://sugarloafdrivebuild.blogspot.com/ Re: Downlights for a timber ceiling? 3Nov 30, 2011 8:00 am You may find that LED is a better option as they produce less heat. The heat is going to be the issue when fitting into timber I think. Re: Downlights for a timber ceiling? 4Nov 30, 2011 10:27 pm I have installed standard downlights into timber ceilings before, the main thing is to make sure that all the fine wood dust that is produced from cutting the hole is cleaned up in the roof space as this is the main fire risk. The best option is LED lights but in my opinion the light colour isn't very nice it will take time for the industry to develop the same colour as normal incandesent lights which is a nice warm colour. Make sure you allow the electrician the extra time to do this job properly as you only get 1 chance, you can't patch a timber ceiling so time is needed for marking out and checking whats above before pointing a holesaw at your very nice ceiling. Cheers Re: Downlights for a timber ceiling? 5Apr 26, 2012 1:15 am aussieal Hi All, I have recently built a timber deck in an alfresco area and am planning to clad the ceiling to match. The ceiling will need downlights installed and i have noticed that most 'standard' dls state not for use in timber... ...does anyone have suggestions for products that are suitable? Google brings up lots of pictures of timber ceilings with DLs installed but i find precious little info on what to use. Regards, Al Hi, I am sorry if this is the wrong place to put this but this is my first attempt on this site. I am unsure about different materials which can be used for an outside ceiling in the wood look without paying the wood price. Can anyone help me or point me in the right direction..........sorry if this is completely off your subject line. Deb Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15826 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10605 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5828 |
