Browse Forums Renovation + Home Improvement 1 Aug 14, 2011 7:14 pm I am considering rennovating my house3 b/r house in 4 b/r. plans are to add 3 bedrooms and small bathroom as a second storey and reconfigure existing 2/3 bedrooms downstairs to make a living area. Is it likely to be cheaper to build on the existing building entirely,or to build halfway into the roof and build out and up (over existing outdoor bbq/paved area) on beams/supporting structure? Additional floor area will be about 70-75m2... Thanks for any help!!! Nina Re: Rennovating on existing structure or to renovate outward 2Aug 16, 2011 3:54 pm Cost will depend on the following: 1.How strong the current frame is. If it can't take the extra weight you'll need to add strength somehow. Also by removing internal walls on the ground floor you may need even more reinforcing to take the weight. 2.How you want to fit it out. I would think it would be easier to go up on a new extension as you can specify how much weight the new lower level needs to carry. Bu tin terms of price I doubt it would make a lot of difference. Re: Rennovating on existing structure or to renovate outward 3Aug 29, 2011 1:53 pm I think you can easily add the wall on your upstairs, but to remove a internal wall, any professional builder will need engineer plan for that. also about the small bathroom, there is plumbing issue about that too. There is no reason why building contract reconciliation cannot be done prior to handover, if the builder won't do it get someone to do it for you. Why would you pay for… 3 5014 8 3031 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 8160 |
