Browse Forums Renovation + Home Improvement 1 Jul 10, 2011 11:14 pm About to renovate and will need to move these connections to another room. We have underfloor access, so should be a matter of disconnecting, drilling a hole and then moving. Is it that simple or are one or other of these difficult to do? Just want to avoid $200 call out calls if I can...... Re: Moving phone, internet and TV connections 2Jul 11, 2011 9:56 am no expert here.....but. Usually there isnt much slack left in these type of cables so unless the rooms you are moving them to are closer to the point at which they come in you will have to run new cableing. You could splice new lengths but that far from ideal, its best to run a whole new cable. Youtube would have some tutorials and most hardware stores have all the bits and tools you would need. Re: Moving phone, internet and TV connections 3Jul 20, 2011 12:49 pm By all means you can move your TV points... No drama's there and Bunnings will even sell you the various suitable terminations and crimps you'll need... Moving phone and internet points... Unless you have a telecom license, highly illegal and regularly prosecuted! You could organise to predrill the suitable holes, mount the wall plates, but the terminations must be completed by a licensed cabler! Electrical Engineer... Don't hold that against me... And keen owner builder... Mainly the building part!! Building Standards; Getting It Right! It's all good. You can get both wye piece and the coupling with or without thread. The cost difference is negligible and means the plumber only has to carry the single… 1 4917 Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 72337 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10032 |
