Browse Forums Renovation + Home Improvement Re: How to remove an old bath? 2Jun 13, 2011 11:24 am I moved one of these in my first house and they weigh a tonne. Best to break away the hob (sidewall) and then undo the waste with a wrench. Once free of the floor you will probably find it is recessed into the stud wall and sitting on the hob, so now just a case of lifting 150Kg and negotiating tight doorways. Be careful not to rest or drag it on your floors you will end up with cracked tiles/scratched timber boards! Building an Eden Brae Saville 27 http://karry327.blogspot.com/ Building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=44247 Re: How to remove an old bath? 3Jun 13, 2011 3:23 pm We undid the waste and then took to it with a sledge hammer. It was very loud, but satisfying! We couldn't lift the bath out whole...God knows how they got it in there in the first place! How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5946 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11835 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7074 |
