Browse Forums Renovation + Home Improvement 1 May 27, 2011 9:12 am Hi, Has anyone seen or used Duraplank for cladding on their house? Apparently it's a new range from Austech which looks a lot better than their current vinyl cladding range Duratuff. http://www.austech.com.au/pressreleases ... dding.aspx Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12034 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11108 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5642 |
