Browse Forums Renovation + Home Improvement 1 Apr 04, 2011 9:42 am Hi guys
we have had a bit of a problem with a concreter who has not put enough slope on the concrete laid outside the garage so when it rains our garage floods. I am thinking of getting a drains/grill cut into the concrete outside the garage door to take the water away to a nearby drain. What sort of person would do this? a concreter or who? And can anyone recommend one in the Caroline Springs area of Melbourne? cheers Chris Re: what sort of tradie would do this? 3Apr 04, 2011 11:07 am As it involves drainage then technically should be a plumber, though depending on who you get you may also want to look into getting a concrete cutter to cut the concrete to allow the drain to be fitted. Our Build - Places Fairhaven 23+ - https://forum.homeone.com.au/viewtopic.php?f=31&t=28045 Our Landscaping - Belial's Backyard - https://forum.homeone.com.au/viewtopic.php?f=19&t=45375 Re: what sort of tradie would do this? 6Apr 07, 2011 6:43 am heres some pics finally! http://i1139.photobucket.com/albums/n55 ... G_2501.jpg http://i1139.photobucket.com/albums/n55 ... G_2500.jpg http://i1139.photobucket.com/albums/n55 ... G_2499.jpg http://i1139.photobucket.com/albums/n55 ... G_2498.jpg http://i1139.photobucket.com/albums/n55 ... G_2497.jpg bascially the right hand corner as you look at the garage from the outside is where it appears to flood Re: what sort of tradie would help with this? 9Apr 13, 2011 7:46 pm qaz well you can put grated drain and plumber can do it or give me a ring 0434723811 how fare is you rain water pipe Rwp form the garage hi mate in this photo http://i1139.photobucket.com/albums/n55 ... G_2500.jpg you can see where the drain is - just round the corner. what sort of money are we talking to get a plumber to do this? just a rough estimate is fine! cheers Re: what sort of tradie would help with this? 11Apr 13, 2011 8:00 pm if you called the plumber before the concrete was laid then no problem. You could have done it your self. I don't think a plumber is going to want to cur out the concrete., Re: what sort of tradie would help with this? 12Apr 15, 2011 8:47 pm we had our plumber do it, they usually have a jack hammer and all sorts of crazy drills to do the job....my plumber is actually pretty handy, i always thought they just did pipes and stuff! Good luck! Make your own Organic Vegetable Patch, Learn How to Build a Pergola http://www.homestyledesign.com.au Unless there were unforeseeable issues with the site, I dont think you should have to pay for contractors errors or poor planning. I'd probably try and be reasonable and… 5 4529 Bought in Nov 21 at the height of the market (classic). Good area, atrocious floor plan. BUT has land out to the left-hand side that we can extend out on (see second… 0 8774 |
