Browse Forums Renovation + Home Improvement 1 Mar 20, 2011 8:29 am Hi all, I need to demolish the old flat roof small extension to my semi detached house as part of my renovations. Currently there is a small dining room and laundry attached that needs to go. I am doing the extension as an owner builder and have all tradesmen organised. However I am wondering if demolition is something I can do myself or do I need someone who is licensed to do the work. Re: Demolishing old extension to our semi detached house 2Mar 24, 2011 8:14 pm It depends on which State you are in but in Victoria, you generally need a building permit for demolition if you are removing any external walls, balconies, part of a roof, etc. From what I understand, owner builders usually don't obtain building permits for demolition work but if you do, you will need to show your building surveyor that you have the knowledge, experience, equipment etc as required by the building regs. Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 26276 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 9246 Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 10436 |
