Browse Forums Renovation + Home Improvement 1 Oct 03, 2024 2:49 pm Hey guys, my wife and I are wanting to find out if ceiling vaulting is possible based on the rafter framing that we already have. It's an old home built in 77, supporting metal roof sheets above, so not a lot of weight. I am just wondering if anyone can spot limitations here, are we stuck with our low ceilings? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Can I vault the ceiling? 2Oct 04, 2024 10:08 pm You currently have lots of ceiling and roof loads on your internal walls. A vaulted ceiling is possible but you need a good carpenter to look at redistributing the loads, the ridge beam and the underpurlins need support. what's the rationale on this? In my mind, the risk weepholes mitigate isn't solved by acrylic render. 9 42542 Many thanks for your reply. Yes I am concerned with the work done. I have another problem with my contractor and I hope this next investigation and review with the… 2 20054 Curtain Ceiling Track Installation Advice? With the last 20cm of the ceiling track on an angle, could it be as simple as: 1. Bending the track slightly to match the… 0 19106 |
