Browse Forums Renovation + Home Improvement 1 May 19, 2024 6:00 pm My water tank is not filling as expected and I have narrowed it down to a leak somewhere - but where. The pvc runs from the guttering runs into the ground. I have examined the ground that sits in the location that I believe is above the pipe but cannot see any boggy ground or suggestion of water. Is there a way this leak can be detected without digging up the entire system? thanks Re: Detect leaking pvc pipe undergound 2May 19, 2024 7:50 pm The leak will usually (but not always) be at a fitting, an elbow for example. Are you on reactive soil? 3in1 Supadiverta. Rainwater Harvesting Best Practice using siphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost, siphonic, eaves gutter overflow solution. Re: Detect leaking pvc pipe undergound 4May 20, 2024 8:29 pm My first suspect area is at the bottom of the harvested downpipe in the sunniest spot. PVC downpipes expand and contract with heat and cold, putting pressure on the below ground fitting. Good luck with finding the culprit. 3in1 Supadiverta. Rainwater Harvesting Best Practice using siphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost, siphonic, eaves gutter overflow solution. The coupling, which is made from flexible PVC, needs to comply with AS/NZS 4327 which specifies the requirements for metal banded flexible couplings used in low-pressure… 1 5290 DIY, Home Maintenance & Repair Hi all, Iām after some advice. I have a leak from upstairs waste pipe behind kitchen wall/kitchen oven. The house was built in 1998. The wall is damp and the leak has… 0 1784 |
