Browse Forums Renovation + Home Improvement 1 Jan 31, 2023 8:28 pm navylion Building a Wisdom Homes Manhattan 35 in Sydney North West MyBuildTimeLine: http://navylion.wixsite.com/mybuildtimeline Re: Converting Alfresco to Outdoor Kitchen\Barbeque 3Feb 01, 2023 9:03 am navylion Building a Wisdom Homes Manhattan 35 in Sydney North West MyBuildTimeLine: http://navylion.wixsite.com/mybuildtimeline Re: Converting Alfresco to Outdoor Kitchen\Barbeque 5Feb 01, 2023 9:23 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Converting Alfresco to Outdoor Kitchen\Barbeque 6Feb 01, 2023 9:26 am navylion Building a Wisdom Homes Manhattan 35 in Sydney North West MyBuildTimeLine: http://navylion.wixsite.com/mybuildtimeline Re: Converting Alfresco to Outdoor Kitchen\Barbeque 7Feb 01, 2023 9:30 am navylion Building a Wisdom Homes Manhattan 35 in Sydney North West MyBuildTimeLine: http://navylion.wixsite.com/mybuildtimeline Re: Converting Alfresco to Outdoor Kitchen\Barbeque 9Feb 01, 2023 11:03 am navylion Building a Wisdom Homes Manhattan 35 in Sydney North West MyBuildTimeLine: http://navylion.wixsite.com/mybuildtimeline Re: Converting Alfresco to Outdoor Kitchen\Barbeque 10Feb 01, 2023 11:04 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Converting Alfresco to Outdoor Kitchen\Barbeque 13Feb 01, 2023 11:38 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Converting Alfresco to Outdoor Kitchen\Barbeque 14Feb 01, 2023 7:01 pm navylion Building a Wisdom Homes Manhattan 35 in Sydney North West MyBuildTimeLine: http://navylion.wixsite.com/mybuildtimeline Re: Converting Alfresco to Outdoor Kitchen\Barbeque 15Feb 01, 2023 7:54 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Converting Alfresco to Outdoor Kitchen\Barbeque 16Feb 02, 2023 12:39 pm ![]() @NavyLion What is at the top of the opening? Is it a lintel with brick, a timber beam or what? You obviously have your slab across the bottom and bricks up both sides it's a pretty simple conversion. Hi Chippy, Thanks for your thoughts. Attached here is the alfresco outdoor and the side I wanted to install the brick wall. There is a metal beam on top (or between) of the two brick piers Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My (budget) concern is if I will do (a) a single brick wall veneer 1 meter height and 3.25 metre width\length and then install a stud\timber frame for the bifold window. Or (b), double brick wall, same length and height, on top of it is the stud\timber for the bifold window. I do have about 2 pallets of extra bricks (left over for my building constructions). Ta, Navy navylion Building a Wisdom Homes Manhattan 35 in Sydney North West MyBuildTimeLine: http://navylion.wixsite.com/mybuildtimeline Re: Converting Alfresco to Outdoor Kitchen\Barbeque 17Feb 02, 2023 5:31 pm You can do either brick veneer or double brick it really doesn't matter. I'd probably frame up the inside and line it with villaboard or blue board after any rough in is completed. Fix off brick ties to the frame and brick up the external. If you really want to do a good job get the brick layer to rod the joints back into the existing brick work. Basically build your wall to form up your opening. The window company will do a site measure. Get them to install a sill tray on the bottom to prevent water ingress under the window. The new window will sit on that and the sides and head will be supported by aluminium trims that are fixed mechanically and with adhesive to the side walls and lintel. A simple 5 panel bifold that stacks at one end will give you sashes around 650 each. It's a pretty simple job, no need to overthink it. Just another question, what are the bits sticking up near your fence? It almost looks like you allowed provision for water, drain and electrical out there. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Converting Alfresco to Outdoor Kitchen\Barbeque 18Feb 03, 2023 12:59 pm ![]() You can do either brick veneer or double brick it really doesn't matter. I'd probably frame up the inside and line it with villaboard or blue board after any rough in is completed. Fix off brick ties to the frame and brick up the external. If you really want to do a good job get the brick layer to rod the joints back into the existing brick work. Basically build your wall to form up your opening. The window company will do a site measure. Get them to install a sill tray on the bottom to prevent water ingress under the window. The new window will sit on that and the sides and head will be supported by aluminium trims that are fixed mechanically and with adhesive to the side walls and lintel. A simple 5 panel bifold that stacks at one end will give you sashes around 650 each. It's a pretty simple job, no need to overthink it. Just another question, what are the bits sticking up near your fence? It almost looks like you allowed provision for water, drain and electrical out ther Thanks for the detail and step by steps process. Yes, I had provisions for an outdoor kitchen, hot and cold, electrical, gas, and drainage as well. navylion Building a Wisdom Homes Manhattan 35 in Sydney North West MyBuildTimeLine: http://navylion.wixsite.com/mybuildtimeline Re: Converting Alfresco to Outdoor Kitchen\Barbeque 19Feb 03, 2023 1:23 pm ![]() ![]() You can do either brick veneer or double brick it really doesn't matter. I'd probably frame up the inside and line it with villaboard or blue board after any rough in is completed. Fix off brick ties to the frame and brick up the external. If you really want to do a good job get the brick layer to rod the joints back into the existing brick work. Basically build your wall to form up your opening. The window company will do a site measure. Get them to install a sill tray on the bottom to prevent water ingress under the window. The new window will sit on that and the sides and head will be supported by aluminium trims that are fixed mechanically and with adhesive to the side walls and lintel. A simple 5 panel bifold that stacks at one end will give you sashes around 650 each. It's a pretty simple job, no need to overthink it. Just another question, what are the bits sticking up near your fence? It almost looks like you allowed provision for water, drain and electrical out ther Thanks for the detail and step by steps process. Yes, I had provisions for an outdoor kitchen, hot and cold, electrical, gas, and drainage as well. You'll just need to move the services over before you start so you can get them roughed in after you frame up. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and… 2 19069 My Electrical roughing is going on. What type of Outdoor heater recommended in Alfresco sized 3000mm x 3000mm below. I asked electrician to give 15amp power point in… 0 14162 If I hire a contractor to convert a window to a sliding door will I need to show them Council approval paperwork? That is, if I want to take a risk of carrying out the… 0 20337 |
