Browse Forums Renovation + Home Improvement 1 Aug 17, 2022 5:42 pm We bought a house built in the early 1990s at Blackburn North, Victoria a few years ago. Despite not being noted in the pre-purchase property inspection, we have since have found the floor to be very bouncy (e.g. crockery rattles when the dogs run about) and creaky to walk on. The subfloor spec called for: * concrete stumps * 100 x 75 F8 bearers @ 2100 max crs, Span max 1700, 1100 under load bearing walls * 100 x 50 F8 floor joists @ 450 max centres (spanning 2100) Spec also notes: "Timber sizes and framing to be In accordance with AS 1684 - Timber Framing Code or Timber Framing Manual or AS 1720 Timber Structures Code". As built appears to match the spec. Looking under the floor, these spacings seem very sparse compared to an extension we built at our old place (also in the 1990s) as well as new builds going up in our area. Should this design be OK (in which case we will need to explore the foundations themselves I guess) or are bouncy floors a feature of this sort of design? Is there maybe a "poor workmanship" aspect we should explore (e.g. sheet flooring not properly fixed)? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Bouncy floor in 1990's home 2Aug 25, 2022 5:00 pm Floor joist arrangement seems ok provided they are of continuous span (single span 1700) Bearer at 2100c max span should be 1700 for cont. or even as low as 1500 for single. Maybe that's where your bounce is. Seems a bit of space under your floor, why don't get under there and have someone walk around inside. If it the bearer bending, just gun nail another piece of timber from stump to stump in the areas of concern. Re: Bouncy floor in 1990's home 3Aug 25, 2022 7:03 pm oldchippy Floor joist arrangement seems ok provided they are of continuous span (single span 1700) Bearer at 2100c max span should be 1700 for cont. or even as low as 1500 for single. Maybe that's where your bounce is. Seems a bit of space under your floor, why don't get under there and have someone walk around inside. If it the bearer bending, just gun nail another piece of timber from stump to stump in the areas of concern. Thanks - there's space at this end, but less at the other end . If the design is OK, then what you've suggested is the next step I guess. CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16901 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17734 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16963 |
