Browse Forums Renovation + Home Improvement 1 Mar 31, 2022 9:50 am Hello, I have to re-attach my fathers metal gate to some brick pylons on either side. However because I have to use dynabolts I'm not sure what is the correct size dyna for the holes on the hinges. I'm not really experienced with using dynas but with the 2 options I have in the photo I've attached I can see how either would work but what one is actually the correct option? I've seen a few threads where people have suggested attaching a peice of wood on the brick first then putting the gate hinges on but that would push each side of the gate into each other and it would not close. Thanks. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Which size dynabolts should I use? 2Mar 31, 2022 1:01 pm Dynabolts are not great for hinges. The dynamic loads loosen them. I’d use a chemical anchor with 10mm gal or stainless rod and washers with nyloc nuts. That is why the timber was recommended. Re: Which size dynabolts should I use? 4Mar 31, 2022 2:31 pm Pulse Dynabolts are not great for hinges. The dynamic loads loosen them. I’d use a chemical anchor with 10mm gal or stainless rod and washers with nyloc nuts. That is why the timber was recommended. Yep I agree a chemical anchor would work well. Will never move. Go to bunnings and ask for the Ramsett Chemset and get some advice from one of their staff. We use Chemset when anchoring reo into rock for retaining wall footings and the stuff is amazingly strong. Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Which size dynabolts should I use? 5Mar 31, 2022 2:41 pm Thanks Ashington Homes, I think I'll return the dynabolts and get what you guys suggest. Cheers. Re: Which size dynabolts should I use? 6Mar 31, 2022 2:47 pm AxeMaster Thanks Ashington Homes, I think I'll return the dynabolts and get what you guys suggest. Cheers. Make sure you wear gloves when you use it, the stuff is lethal (think superglue times by 100) Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Which size dynabolts should I use? 7Mar 31, 2022 2:55 pm Thanks again, quick Q...if I use say 8mm anchor bolts, should I drill 8mm holes or 10mm? I'm thinking does the hole have to be a bit wider cos your filling it with the chemset and it might need a bit more space inside to surround and affix to the bolt properly. cheers. Re: Which size dynabolts should I use? 8Mar 31, 2022 2:58 pm AxeMaster Thanks again, quick Q...if I use say 8mm anchor bolts, should I drill 8mm holes or 10mm? I'm thinking does the hole have to be a bit wider cos your filling it with the chemset and it might need a bit more space inside to surround and affix to the bolt properly. cheers. yes your hole will need to be bigger then the item you are inserting Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Which size dynabolts should I use? 10Mar 31, 2022 3:06 pm AxeMaster Thanks. Interestingly, if you have an existing hole that is way too big, ie you accidentally drilled a 40mm hole and you want to insert an 8mm bolt, they also have a product that will fill that larger hole for you. Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Which size dynabolts should I use? 12Mar 31, 2022 3:37 pm AxeMaster A mate of mine suggested to drill a hole, fill it with liquid nails and then put the bolt in. I did something similar years back. lol I wonder if that would work, never tried liquid nails in a hole. It's pretty amazing stuff. On a gate though the fixtures are subject to some pretty decent forces as you open and close the gate, so probably wouldnt be the best idea. You could also plug the hole and use 75mm bugles. Not the most professional option but does work. And then stepping up a notch Ramsett do have a bunch of decent screw anchors, so ask you local bunnings dude Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Which size dynabolts should I use? 13Mar 31, 2022 3:47 pm One last question, really appreciate your time and help. Should I use a perforated sieve in the hole as well. So, drill the hole, put the sieve in, put in the chemset in, then the bolt. For extra grip and strenght. It's solid brick. Re: Which size dynabolts should I use? 14Mar 31, 2022 3:52 pm AxeMaster One last question, really appreciate your time and help. Should I use a perforated sieve in the hole as well. So, drill the hole, put the sieve in, put in the chemset in, then the bolt. For extra grip and strenght. It's solid brick. just drill the hole Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Which size dynabolts should I use? 18Apr 04, 2022 2:00 pm Going to get the anchor bolts and chemset from Bunnings this week. But I came across these hinges from Amazon.com.au (US stock) last night that look interesting. Don't know about what kind of weight they can hold though. Anyone seen something similar availble in Oz? I like the fact that the part that attaches to the gate is adjustable, but again don't know how much weight they can hold. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7414 All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3635 Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks 0 3525 |
