Browse Forums Renovation + Home Improvement 1 Jan 01, 2022 11:14 pm Hi Folks, I am planning to build the slatted wall in my theatre room and was wondering if anyone have idea what kind of wood I should be purchasing. I got quite good idea on installation process but not able to sure what k8nd of timber I should purchase that I can cut, sand and install. Attached photo is for idea on what kind of slatted wall I want to create Thanks Vivek Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Vin Re: Building internal slatted wall 2Jan 01, 2022 11:52 pm It really comes down to the particular look (grain , colour.wnd dimension) that you are after and the cost. There is a lot of material in a wall like that. Cheapest option is clear pine, stained and finish in an appropriate colour, otherwise if you are looking for more grain then you will start paying premium dollars. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Building internal slatted wall 3Jan 01, 2022 11:53 pm chippy It really comes down to the particular look (grain , colour.wnd dimension) that you are after and the cost. There is a lot of material in a wall like that. Cheapest option is clear pine, stained and finish in an appropriate colour, otherwise if you are looking for more grain then you will start paying premium dollars. Thanks Chippy for the response. Would you be kind to share some links of products e.g. Bunnings or other sellers so I can take a look and make decision appropriately. Cheers Vivek Vin Re: Building internal slatted wall 4Jan 02, 2022 12:33 am vin83 chippy It really comes down to the particular look (grain , colour.wnd dimension) that you are after and the cost. There is a lot of material in a wall like that. Cheapest option is clear pine, stained and finish in an appropriate colour, otherwise if you are looking for more grain then you will start paying premium dollars. Thanks Chippy for the response. Would you be kind to share some links of products e.g. Bunnings or other sellers so I can take a look and make decision appropriately. Cheers Vivek The cheapest option would be 42x19 pine from bunnings https://www.bunnings.com.au/42-x-19mm-2 ... m_p8401458 You could then go similar size in Tassie oak https://www.bunnings.com.au/porta-40-x- ... t_p0081767 After that you would need to see a specialist timber supplier in your state Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Building internal slatted wall 5Jan 02, 2022 11:30 am chippy vin83 chippy It really comes down to the particular look (grain , colour.wnd dimension) that you are after and the cost. There is a lot of material in a wall like that. Cheapest option is clear pine, stained and finish in an appropriate colour, otherwise if you are looking for more grain then you will start paying premium dollars. Thanks Chippy for the response. Would you be kind to share some links of products e.g. Bunnings or other sellers so I can take a look and make decision appropriately. Cheers Vivek The cheapest option would be 42x19 pine from bunnings https://www.bunnings.com.au/42-x-19mm-2 ... m_p8401458 You could then go similar size in Tassie oak https://www.bunnings.com.au/porta-40-x- ... t_p0081767 After that you would need to see a specialist timber supplier in your state Thanks a lot Chippy. This will help a lot. Will share photos once I complete the wall Cheers Vin Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 7945 3 10218 Sorry, don't know costs, but there are a couple of very important principles you need to get right (and now) .... (1) never agree to any "upgrade" unless you first know… 5 6854 |
