Browse Forums Renovation + Home Improvement Re: Should we go ahead with double story extension on top of 5Jan 23, 2022 11:08 am Regards, Colin Operations Director Homebuildguide.com.au Click Here For A Free eBook About Custom Home Building Re: Should we go ahead with double story extension on top of 8Jan 23, 2022 3:57 pm Regards, Colin Operations Director Homebuildguide.com.au Click Here For A Free eBook About Custom Home Building Re: Should we go ahead with double story extension on top of 9Feb 12, 2022 8:09 am Homebuildguide-Colin Hey vov How's the project coming along? If you want to find out if the project is feasible, you should have an engineer assess it. The builders will not know anything about the foundations, so they will make assumptions. Civil engineers can tell you if it's feasible and what's involved. I've worked on a few of these in the past, so I know they can be done. In the worst case scenario, you may need extra reinforcements. A engineers report would cost you less than $1,000 & it would tell you if the project is feasible or not. From a quick look at your plan, it seems very straightforward. The only slightly tricky part might be the beams that must be cantilevered over the garage. However, it shouldn't be a major problem. What is your budget for the project? Hi Homebuildguide-Colin, Do you have any recommendation for structural engineering firm? Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8505 We bought land in Tallawong Schofields NSW size 30m X 12.5m and planning to get double story house build around 350 sqm. We are thinking about having premium inclusions… 0 4099 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31283 |
