Browse Forums Renovation + Home Improvement 1 Jul 29, 2021 5:58 pm Hey everyone First time poster and hoping for some assistance. Well after saying 3 kids enough, my wife is pregnant with our 4th ( surprise). As a result we have decided to convert our attached garage into some new living areas/bedrooms. The situation at the moment is the builder is currently inspecting the slab, and so far has not been able to find any plastic waterproofing membrane under the slab. The slab however is around 20-30cm thick. What is the best way around this situation if we cannot find the membrane? We are seriously worried about rising damp and mould so hoping we still have an option to do this reno. Is the worst case to rip it up and pour a new slab? or are there other options? The builder has made some suggestions but i am a bit worried - he said there is a chemical you can paint on top to seal it, but then what about when we put carpet in and puncture the floor? or dynabolting the walls into the slab? won't this damage the integrity of the sealant? Thanks, p4peel Re: Converting garage - slab 2Aug 04, 2021 12:47 pm Hey p4peel welcome to the forum garage and alfresco conversions are very popular atm here Need ideas to converts alfresco into bedroom You will need to check your house engineering plans Generally an alternate DPM solution will need to be certified Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Converting garage - slab 3Aug 04, 2021 3:37 pm You will need a building permit to convert a garage into a habitable room so you should in the first instance speak to the council building surveyor if you want free advice. If you have enough ceiling space you may be able to put timber floor on top of the slab but ultimately any solution must be acceptable to the relevant building surveyor. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog 2 9446 If I hire a contractor to convert a window to a sliding door will I need to show them Council approval paperwork? That is, if I want to take a risk of carrying out the… 0 13009 start from at least $20,000 just for fixtures and finishes and then add on for moving plumbing and extra for a concrete floored house last new bathroom we installed in a… 1 19586 |
