Browse Forums Renovation + Home Improvement 1 Jun 10, 2021 2:03 pm I need help regarding my noisy exhaust fan. The exhaust fan is making squeaky and then flapping noise. It is particularly loud during windy day. The exhaust fan is ducted to the outside. The model is Trader Falcon FNCEFDR. How do I fix this? Would replacing the external vent cover with something like this help? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I read about installing a butterfly backdraft shutter in the ductwork. But the exhaust fan is already equipped with a backdraft shutter. Will this work? Or is there a better exhaust fan than the one I have? My friend has got a clipsal CEF40 exhaust fan (also ducted to outside) and they have no noisy exhaust fan problem. Thanks in advance. https://www.gsme.com.au/products/falcon-ducted/fncefd Re: Exhaust fan noisy - squeaking and flapping noise 2Jun 10, 2021 2:33 pm The backdraft shutter is probably what is making the flapping noises in windy weather. Only way to fix it is to have one that doesn’t flap. Only way I have surmised to make that work is to install a manually or electrically activated one. Re: Exhaust fan noisy - squeaking and flapping noise 3Jun 10, 2021 2:35 pm It's probably an expensive solution but you could look at one of these. https://www.schweigen.com.au/catalogue/brw600 The motor unit is installed on the outside of the house which would mean with a back draft stopper there would be nothing inside the house except the tubing so wind shouldn't make a difference. Re: Exhaust fan noisy - squeaking and flapping noise 4Jun 10, 2021 3:19 pm arcadelt The backdraft shutter is probably what is making the flapping noises in windy weather. Only way to fix it is to have one that doesn’t flap. Only way I have surmised to make that work is to install a manually or electrically activated one. Do you have an example of this sort of exhaust fan which has an electrically activated backdraft shutter? My home office is hot with computer equipment running virtually 18 hours a day. When it gets unbearably warm I simply step out of my door into the living area which is… 0 3672 18 74390 Hi, I have a double and whenever the wind picks up I can hear alot of banging in certain areas of the house. I've had a look round and can't see any obvious issue but… 0 8898 |
