Browse Forums Renovation + Home Improvement 1 May 31, 2021 10:48 pm Hi everyone, I have some builders re-cladding a building on our property with vertical corrugated Colorbond. They have done the roof and walls, and are now doing the gutters. I noticed they haven't put any flashing between the eaves and the top of the walls. Although the gutters cover the gap, I am concerned this will leave the roof vulnerable to wind. Can anyone tell me if it is standard (to code) to install flashing between the eaves and the walls? Thanks in advance, Cheers Jon 1 19709 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4891 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10139 |
