Browse Forums Renovation + Home Improvement Re: Laminate Flooring - Expectation 2May 28, 2021 6:13 am Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Laminate Flooring - Expectation 10Jun 01, 2021 1:15 pm Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Laminate Flooring - Expectation 13Jun 01, 2021 5:06 pm I am just a typical consumer albeit with experience of 2 successful floating floor installations after some mucking around to get them right. The flooring retailer, distributor, importer, agent...would be better placed to answer your question, however i doubt a thicker underlay will solve the problem. May even make it worse. The boards are engineered to be very flat and they need a flat firm surface to 'float' on. Re: Laminate Flooring - Expectation 14Jun 10, 2021 12:22 pm Thought its good to share some updates regarding the problem I am having with my laminate flooring; hope it might benefit others who experience the same problem. The retailer organized the manufacturer to come and inspect the floor and they did come today. They acknowledged that there are couple of problematic spots around the house; and will work towards solution. The check was quite thorough and some general findings are as follow 1\ Uneven subfloor (no surprise here) - the funny thing is those that are uneven are actually quiet (not making noise at all) 2\ Though in general the sub floor is okay in terms of flatness and level 3\ Some of the planks joint are not tight enough 4\ They might need to make bigger / wider gap along the perimeters to release the tension It is a combination of few factors - but was promised that they will fix them Regarding the noise / sound 1\ Consistent clicky noise was identified and they will try to find the best solution to rectify 2\ Dry noise will disappear overtime In my humble opinion, the onus is on the retailer and its team of installer to rectify (or at lease analyze) problems raised by customers - at the minimum they should at least come and check (although I am not entirely sure what the normal process is in the flooring industry) I am glad, although it will take time to rectify - that this does not turn out to be a blaming game. I did mention the laminate brand that I have - and from this experience alone I m glad I purchased their brand. It seems to be a business that is well run and looking to be in the game for a long term. Re: Laminate Flooring - Expectation 15Jun 10, 2021 4:47 pm My first floating floor installation had some clicking and popping noises. The installer blamed the boards (retailer), and the retailer blamed the floor leveller and installer... At the completion of the work they all wanted to be paid for their parts separately until i pointed out to them that the retailer's quote was for 'supply and install' and the invoice would not get paid until the job was done correctly. They argued for a few days then worked together to fix it. Re: Laminate Flooring - Expectation 16Jun 21, 2021 7:27 pm Another update: the floor guy sent by the manufacturer came to try fixing a few planks. His method was to drill a few holes in between the planks and injected glue. It seems to be working. It looks like he will need to spend 2 to 3 days to get them fixed. Re: Laminate Flooring - Expectation 17Jul 24, 2021 11:19 am Hi again - hope everyone is safe! Need opinion here. Long story short both manufacturer and shop have come to an agreement that the installation was not properly done and they have agreed to re-install the floor (laminate floorboard). The installer and the manufacturer will do the installation together; to ensure it is properly done. Is there anything else that I need to be aware of to ensure that the installation is properly done this time (self level, choice of underlay, etc, gluing the joint, etc?) Do i need a new floorboard? or the old one can be re-used if they can be re-used? Thanks again Re: Laminate Flooring - Expectation 18Jul 27, 2021 1:20 pm Check the levelness requirement specification of the boards and check your floor surface to the mm after its been levelled to ensure your boards and new base surface will be happy together. Just about completed a renovation project and hit a small issue that we didn’t see We have laminate floors now where we had tiles before (turned out it was actually 2… 0 4932 DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6332 We are doing heaps of hybrid at the moment and the cost sits between $60-65/sqm including installation. Stairs are around $90-100 each 1 4311 |
