Browse Forums Renovation + Home Improvement 1 May 07, 2021 7:50 pm Our 60s home upstairs has sloped ceilings almost throughout which are attatched to the rafters through ceiling battens. That is all the ceilings except the bathroom which is flat. I plan on extending the bathroom so I have pulled down the bathroom ceiling and wall, with the wall extending to the rafters. There was nothing special in the wall frame with the joists nailed directly in to the studs resting on a 'cross beam notched in to the studs. Apart from holding up the bathroom ceiling, the bathroom wall is essentially not load bearing as it's not holding up any of the roof structure. I want to rebuild our new bathroom wall with a flat roof and place in new ceiling joists with proper span size. I am wondering if there is any other structural considerations due to the wall technically being load bearing despite our modest bathroom size. Re: Adding a wall and ceiling joists 2May 09, 2021 11:40 am Try putting up a rough sketch, photo, etc The better the information the better the reply + it helps others. OT, This type of post generally goes unanswered? Words don't get certified .... details do Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Adding a wall and ceiling joists 3May 09, 2021 8:42 pm StructuralBIMGuy Try putting up a rough sketch, photo, etc The better the information the better the reply + it helps others. OT, This type of post generally goes unanswered? Words don't get certified .... details do Cheers Chris Thanks Chris, it makes sense in my mind but it does read terribly. In this very rough side on sketch. We just want to enlargen the bathroom width about 300mm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The bathroom having a flat ceiling will need to support the ceiling joists in the stud wall. The previous stud wall only had a beam notched into it support the ceiling joists. The rest of the wall looked like a standard non load bearing wall. Is this sufficient when I build the replacement wall or is more required? Hi All, about to commence a bathroom renovation and need some advice on subfloor works. Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to… 0 5841 Thanks for all replies. I just noticed now the pictures I added to post right on top of page were wrong. I attached pictures showing "current" and my "suggested" floor… 9 14644 |
