Browse Forums Renovation + Home Improvement 1 Apr 25, 2021 1:17 pm The door handle to one of our bedrooms has fallen off and I wish to reattach it. How do I remove the faceplates though? See photos for more info. I have tried screwing the faceplate counterclokwise (and clockwise) and also prying it off with a screwdriver however have had no luck. Cheers for any help! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: How to remove faceplate from internal door handle (fell 2Apr 25, 2021 1:33 pm The rosette or face plate unscrews off the backing plate. The threaded part is around the spindle and can get quite tight. It is a standard direction thread so anticlockwise is right. You could try spraying a bit of CRC in behind the back plate and hopefully that will help loosen it up. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: How to remove faceplate from internal door handle (fell 3Apr 25, 2021 2:30 pm Thanks Chippy. Some grease and pliers get the faceplates undone and the door handle is now securely back on. Had I known what such a simple job it was I would have done it a year ago rather than had a hole in the door since then DIY, Home Maintenance & Repair Brilliant - thanks so much for that. I didn't want to start pulling too hard on it if there was some other way it was attached, but yep, it was just the paint sticking it… 2 3162 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9070 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6347 |
