Browse Forums Renovation + Home Improvement 1 Apr 17, 2021 9:23 pm Hello guys, I'm renovating my 1950's house currently, and during the removal of kitchen / closets in the room / wallpapers, some of the white set plaster (~2mm thick) came off with the fixtures. Problem is, now the whole layer of them are coming off very easily with fingers / scraper! and I can't stop myself from peeling off more and more. and some more. Eventually whole wall, whole room and whole house might be stripped and left with the grey float plaster. Question is, is it necessarily? The paint and plaster adjacent to these areas seem sound from outside, and only seem to be coming off because I'm lifting them from where damage has occurred. It seems like I'm making the problem worse. Is it possible to re-plaster the damaged area only (mix bag of plasters or joint compound?), feather into the existing remaining white-set, and hope it bonds strongly? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: White Set Plaster - Repair or Burndown the whole house? 2Apr 17, 2021 10:08 pm You can absolutely patch it. Just scrape off any loose or flakey white set and then get it re plastered. You can skim it with top coat if you know what you are doing and then sand it back so it's nice and smooth. Paint with a dealer and you are good to paint it all. In Perth most construction is plastered brick so we do it all the time. All the best. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: White Set Plaster - Repair or Burndown the whole house? 3Apr 18, 2021 11:29 am chippy You can absolutely patch it. Just scrape off any loose or flakey white set and then get it re plastered. You can skim it with top coat if you know what you are doing and then sand it back so it's nice and smooth. Paint with a dealer and you are good to paint it all. In Perth most construction is plastered brick so we do it all the time. All the best. Heya thanks Chippy ! Do I scrape off the whole wall if it keeps on coming off? I ask only because it feels like 'peeling skin around your nails' - you think you should stop, cut & clean but you keep pulling until it bleeds I feel like the whole wall might come off / whole house may get stripped. Do you know of reliable plastering company that will take on this kind of work? Thank you so much. This has been very helpful. We definitely wish to settle and get these people out of our life. They are trying to charge us interest on late… 7 14386 DIY, Home Maintenance & Repair Hi All, Hoping someone might be be to provide some advice on my ceiling that needs repair. Photos attached, but seems like the alcove (??) is pulling away. Thanks Thomas 0 6589 |
