Browse Forums Renovation + Home Improvement 1 Mar 07, 2021 10:21 am Currently hunting for my first property on the Gold Coast. I am aiming for properties less than 20 years old. The first thing I will want to do after purchasing my home is to install a zoned ducted air conditioning system. I know that it's a sizeable financial commitment and and that a split system is generally a cheaper option, but I just have my heart set on the ducted systems. It has come to my attention that not all houses are built to support all types of air conditioning. How can I reasonably be sure that a zoned ducted air conditioning system can be installed in a certain property that I am considering to purchase? Re: How to tell if you can install ducted aircon in a proper 2Mar 07, 2021 10:58 am as long as you have a pitched roof, ducted ac can be fitted, not including raked ceilings 3 phase power already to house would cut down install costs evaporative cooling already fitted would increase costs The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15833 retail its around double the price of a similar sized actron/dakin system from memory, They are excellent systems though. But with how builder gouge on AC/heating, you… 4 14676 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16203 |
