Browse Forums Renovation + Home Improvement 1 Feb 27, 2021 9:19 pm Hello. I've got some 129 furring channel as described in this image. I'd like to use this direct fix application on my shed so I can put up some ecoply sheets for a wall. The current shed structure will put the clips at 1200 spacings; top, middle and bottom, fixing into the steel frame. Do you think this would be suitable for my needs? Or should I add some extra support to make the clips fix at 600 spacings? Thank you. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4610 Need to remove glass panel out of concrete without wrecking the glass to get the spa room in, any recommendations on how to do that. Thank you 0 39143 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4968 |
