Browse Forums Renovation + Home Improvement 1 Dec 10, 2020 2:18 pm Hi all, We are renovating our house at the moment and are stuck with a few decision regarding the existing concrete slab. 1. We are putting in a new ensuite and have to jackhammer out part of the slab for floorwaste. It's pretty close to the edge of the slab (under 1m distance). Do you know roughly how much it would cost? We think it will be around $1000. Will it be cheaper to build up the floor and do a few trick to get the waste out? 2. There is a new column that requires footing support. We are unsure if there is an existing intermediate beam underneath in the slab. Is there anyway we could find out? If there is no footing, again we have to cut up the floor and put in 500sq pad (according to the structural engineer). We think it will be around $2000 extra. Are we way off on both instances? THanks heaps, Re: House Reno - Concrete slab work 2Dec 12, 2020 12:23 pm Welcome to the forum...It helps if you put up plans or photos hoangthach.tran Hi all, We are renovating our house at the moment and are stuck with a few decision regarding the existing concrete slab. 1. We are putting in a new ensuite and have to jackhammer out part of the slab for floorwaste. It's pretty close to the edge of the slab (under 1m distance). Do you know roughly how much it would cost? We think it will be around $1000. Will it be cheaper to build up the floor and do a few trick to get the waste out? Concrete cutting and jacking is the quickest cheapest option Here's a tip you can buy a new cement mixer, cheap saw and jack hammer for < $1k online then sell it when you have completed your renos hoangthach.tran 2. There is a new column that requires footing support. We are unsure if there is an existing intermediate beam underneath in the slab. Is there anyway we could find out? If there is no footing, again we have to cut up the floor and put in 500sq pad (according to the structural engineer). We think it will be around $2000 extra. Are we way off on both instances? THanks heaps, Try drilling through the exact spot and check the concrete depth, though you will probably require a pad footing and slab At a guess .5x.5x.3 (Pad) + 3+3+.1 (Slab) = 1m3 concrete for such a small amount I would batch the concrete in a mixer.. buy the dry concrete mix bulk. Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs The only thing to add to these comments is that where possible it's always good to try and work with people than just say "no" because you can. Having someone… 4 17151 your new kitchen and living area looks great and we need accurate dimensions to be specific but with the thickness of the brick column you may be able to line the inside… 1 1249 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 10103 |
