Browse Forums Renovation + Home Improvement 1 Dec 06, 2020 11:07 am Hi, I'm just looking for some input/advice on if these walls highlighted on attached plan could be removed. We are hoping to open up the kitchen and change the layout from a L shape to a straight run with island bar. The oven is going to be relocated, floors re-tiled, roof will be re sheeted and corniced in kitchen section. Will i need to apply to the council to do this change to the house layout? Im a cabinet maker so will be removing the walls, building kitchen and tiling my self, ill just have trades in to do the gyprock and electrical. Any advice would be very appreciated. Regards Rob. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Domestic House wall removal Queensland. 2Dec 11, 2020 10:54 pm no BA required. just check the wall isn't loadbearing before tearing it down. Re: Domestic House wall removal Queensland. 3Dec 13, 2020 7:42 am Your trusses would only rest on the top plates of the outside walls so it would be safe to assume that those walls you want to remove wouldn't be load bearing. Climb up into your roof space to have a look before proceeding. Stewie Re: Domestic House wall removal Queensland. 4Dec 13, 2020 11:01 am Hey Rob McM welcome to the forum Though the internal walls don't support vertical roof loads they may offer restraint You still need to consider other loads ie, wind racking forces and horizontal shear forces etc, consultant an engineer also Check with your council in which case BA is required Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Hi. 2 questions for any builders our Building Surveyors out there 1. Is the Domestic Building Insurance needed to be obtained before the building permit can be issued? 2.… 0 593 Well, it changed from the Victorian Building Commission to the Victorian Building Authority on 1 July 2013. The same could be asked of that change lol. 2 867 ![]() Hi has this wall been approved under DA or a cdc? As with any wall over 600mm it would require on of these options usually at 1m high you would need an engineer to sign… 2 1302 |
